VTech Kidizoom Smartwatch DX2 Battery Replacement
  1. VTech Kidizoom Smartwatch DX2 Battery Replacement, Master Switch: step 1, image 1 of 2 VTech Kidizoom Smartwatch DX2 Battery Replacement, Master Switch: step 1, image 2 of 2
    • Begin by flipping the watch over with its back facing upwards.
  2. VTech Kidizoom Smartwatch DX2 Battery Replacement: step 2, image 1 of 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: step 2, image 2 of 2
    • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
  3. VTech Kidizoom Smartwatch DX2 Battery Replacement: step 3, image 1 of 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: step 3, image 2 of 2
    • Gently lift the backplate up to remove it.
  4. VTech Kidizoom Smartwatch DX2 Battery Replacement: step 4, image 1 of 3 VTech Kidizoom Smartwatch DX2 Battery Replacement: step 4, image 2 of 3 VTech Kidizoom Smartwatch DX2 Battery Replacement: step 4, image 3 of 3
    • After removing the backplate, lift the master switch up from the circuit board.
  5. VTech Kidizoom Smartwatch DX2 Battery Replacement, Motherboard: step 5, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
  6. VTech Kidizoom Smartwatch DX2 Battery Replacement: step 6, image 1 of 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: step 6, image 2 of 2
    • Carefully remove the speaker from the case without disconnecting it from the motherboard.
  7. VTech Kidizoom Smartwatch DX2 Battery Replacement: step 7, image 1 of 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Using the tweezers, carefully lift the bar holding the connection to the screen.
    • Remove the motherboard from the device.
  8. VTech Kidizoom Smartwatch DX2 Battery Replacement, Battery: step 8, image 1 of 1
    • Carefully pry the battery off of the circuit board using the plastic opening tool.
  9. VTech Kidizoom Smartwatch DX2 Battery Replacement: step 9, image 1 of 1
    • De-solder the wires connecting the battery to the circuit board.
    • Remove the battery.
Jessica Richard
512 Reputation
4 Guides authored
4 Comments
Hey guys, My VTech watch is plugged in but once I turn it on it does but then shows a dead battery. I actually didn’t play with it for a while and I left it dead battery.
Gabriel Baker - Reply
So I might try this trick and see if it works.
Sometime i’ll try it
when I have the right tools
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 70
All Time: 10,301
