VTech Kidizoom Smartwatch DX2 Camera Replacement
Nathaniel Cady
Nathaniel Cady and 4 other contributors
Last updated on December 19, 2018
7 minutes
Moderate
Introduction
Go to step 1
If one of the cameras on your device is broken, cracked, or damaged in any way, the following guide will show you how to replace the camera.
Tools
  1. VTech Kidizoom Smartwatch DX2 Camera Replacement, Master Switch: step 1, image 1 of 2 VTech Kidizoom Smartwatch DX2 Camera Replacement, Master Switch: step 1, image 2 of 2
    • Begin by flipping the watch over with its back facing upwards.
  2. VTech Kidizoom Smartwatch DX2 Camera Replacement: step 2, image 1 of 2 VTech Kidizoom Smartwatch DX2 Camera Replacement: step 2, image 2 of 2
    • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
  3. VTech Kidizoom Smartwatch DX2 Camera Replacement: step 3, image 1 of 2 VTech Kidizoom Smartwatch DX2 Camera Replacement: step 3, image 2 of 2
    • Gently lift the backplate up to remove it.
  4. VTech Kidizoom Smartwatch DX2 Camera Replacement: step 4, image 1 of 3 VTech Kidizoom Smartwatch DX2 Camera Replacement: step 4, image 2 of 3 VTech Kidizoom Smartwatch DX2 Camera Replacement: step 4, image 3 of 3
    • After removing the backplate, lift the master switch up from the circuit board.
  5. VTech Kidizoom Smartwatch DX2 Camera Replacement, Motherboard: step 5, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
  6. VTech Kidizoom Smartwatch DX2 Camera Replacement: step 6, image 1 of 2 VTech Kidizoom Smartwatch DX2 Camera Replacement: step 6, image 2 of 2
    • Carefully remove the speaker from the case without disconnecting it from the motherboard.
  7. VTech Kidizoom Smartwatch DX2 Camera Replacement: step 7, image 1 of 2 VTech Kidizoom Smartwatch DX2 Camera Replacement: step 7, image 2 of 2
    Tool used on this step:
    • Using the tweezers, carefully lift the bar holding the connection to the screen.
    • Remove the motherboard from the device.
  8. VTech Kidizoom Smartwatch DX2 Camera Replacement, Camera: step 8, image 1 of 2 VTech Kidizoom Smartwatch DX2 Camera Replacement, Camera: step 8, image 2 of 2
    • Turn the motherboard so the battery is on the bottom and locate the two clips holding the cameras in place.
    • Carefully lift the clips and slide the cameras out.
Nathaniel Cady
187 Reputation
1 Guide authored
1 Guide Comment
to much and do not under stand it
Aaron Arora - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 821
