VTech Learning Tunes Karaoke LCD Screen Replacement
  1. VTech Learning Tunes Karaoke LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • To remove the battery door, loosen the screw using a Flathead screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Learning Tunes Karaoke LCD Screen Replacement: step 2, image 1 of 2 VTech Learning Tunes Karaoke LCD Screen Replacement: step 2, image 2 of 2
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke LCD Screen Replacement: step 3, image 1 of 1
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke LCD Screen Replacement: step 4, image 1 of 2 VTech Learning Tunes Karaoke LCD Screen Replacement: step 4, image 2 of 2
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke LCD Screen Replacement: step 5, image 1 of 1
  6. VTech Learning Tunes Karaoke LCD Screen Replacement: step 6, image 1 of 1
    • Using Phillips #1 screwdriver, remove the four 7.9 mm LCD board screws.
  7. VTech Learning Tunes Karaoke LCD Screen Replacement: step 7, image 1 of 1
    • Remove old board and screen.
Gregory Timmins
101 Reputation
1 Guide authored
USF Tampa, Team 7-2, Cheng Spring 2016 Member of USF Tampa, Team 7-2, Cheng Spring 2016
USFT-CHENG-S16S7G2
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 340
