VTech Learning Tunes Karaoke Volume Switch Replacement
  1. VTech Learning Tunes Karaoke Volume Switch Replacement, Volume Switch: step 1, image 1 of 1
    • To remove the battery door, loosen the screw using a Flathead screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Learning Tunes Karaoke Volume Switch Replacement: step 2, image 1 of 2 VTech Learning Tunes Karaoke Volume Switch Replacement: step 2, image 2 of 2
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Volume Switch Replacement: step 3, image 1 of 1
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Volume Switch Replacement: step 4, image 1 of 2 VTech Learning Tunes Karaoke Volume Switch Replacement: step 4, image 2 of 2
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Volume Switch Replacement: step 5, image 1 of 2 VTech Learning Tunes Karaoke Volume Switch Replacement: step 5, image 2 of 2
    • Using a Phillips PH1 screwdriver, remove the two 7.9 mm volume switch board screws.
  6. VTech Learning Tunes Karaoke Volume Switch Replacement: step 6, image 1 of 1
    • Once the screws have been removed, carefully move the volume switch board.
  7. VTech Learning Tunes Karaoke Volume Switch Replacement: step 7, image 1 of 1
Lezette Leuterio
101 Reputation
1 Guide authored
USF Tampa, Team 7-2, Cheng Spring 2016 Member of USF Tampa, Team 7-2, Cheng Spring 2016
USFT-CHENG-S16S7G2
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 11
All Time: 424
