VTech Little Apps Tablet Speaker Replacement
Introduction
Go to step 1This guide will help with replacing the speaker located inside of your device. This guide will require soldering.
Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
Remove the two 7.3 mm panhead screws holding down the speaker with a PH0 driver head.
