VTech MobiGo Touch Learning System Case Replacement
  1. VTech MobiGo Touch Learning System Case Replacement, Case: step 1, image 1 of 1
    • Remove the battery covers and the four batteries.
  2. VTech MobiGo Touch Learning System Case Replacement: step 2, image 1 of 2 VTech MobiGo Touch Learning System Case Replacement: step 2, image 2 of 2
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. VTech MobiGo Touch Learning System Case Replacement: step 3, image 1 of 2 VTech MobiGo Touch Learning System Case Replacement: step 3, image 2 of 2
    • Using a plastic opening tool, separate the two pieces of the case carefully.
Daniel Kresge
385 Reputation
4 Guides authored
USF Tampa, Team 8-3, Eyestone Fall 2015 Member of USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Members
17 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 1,060
