VTech Safe and Sound DM111-2 Battery Replacement
  1. VTech Safe and Sound DM111-2 Battery Replacement, Battery: step 1, image 1 of 1
    • Expose the battery compartment by removing the lower back cover of the device.
    • Do this by holding the back side of the device upside down in your hands and applying pressure to the indented portion with both thumbs.
  2. VTech Safe and Sound DM111-2 Battery Replacement: step 2, image 1 of 1
    • Once the batteries are exposed, use your index finger to push the battery against the spring and pull up to dislodge the battery.
    • Make sure to check for battery acid or other corrosive substances before touching the battery. If needed, use latex gloves to avoid skin irritation from battery acid.
Darrell Griffin
222 Reputation
2 Guides authored
USF Tampa, Team 6-3, Remmell Fall 2015 Member of USF Tampa, Team 6-3, Remmell Fall 2015
USFT-REMMELL-F15S6G3
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 34
All Time: 5,295
