VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning
  1. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning, Battery: step 1, image 1 of 2 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning, Battery: step 1, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 2, image 1 of 3 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 2, image 2 of 3 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 2, image 3 of 3
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  3. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 3, image 1 of 3 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 3, image 2 of 3 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 3, image 3 of 3
    • When reassembling, align the notch on the battery panel with the slot on the phone.
  4. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 4, image 1 of 2 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning, Repairing VTech Touch and Swipe Baby Phone Screen Alignment: step 4, image 2 of 2
    • Remove four 13.8mm screws from the back of the device using a Phillips #1 screwdriver.
  5. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 5, image 1 of 3 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 5, image 2 of 3 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 5, image 3 of 3
    • Remove a single 4.8 mm screw with a Phillips #0 screwdriver and lift away the battery pack being careful of the wires.
  6. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 6, image 1 of 2 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 6, image 2 of 2
    • Remove two 7.2 mm screws with a Phillips #0 screwdriver.
    • Slide off the spring.
  7. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 7, image 1 of 3 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 7, image 2 of 3 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 7, image 3 of 3
    • Remove the single 7.5mm screw with a Phillips #0 screwdriver.
    • Lift up the black plastic piece.
  8. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 8, image 1 of 2 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 8, image 2 of 2
    • Remove four 7.5mm screws with a Phillips #0 screwdriver.
  9. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 9, image 1 of 2 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 9, image 2 of 2
    • Remove the two buttons, noting how wires are placed for reassembly.
  10. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 10, image 1 of 2 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 10, image 2 of 2
    • Lift the button board up and away to clear room for lifting the motherboard.
    • Tilt the assembly up but being wary that it is still attached to the front panel.
  11. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 11, image 1 of 1
    • Slide the toothed slider towards you to remove.
  12. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 12, image 1 of 1
    • To reassemble, align the two black lines together by moving the belt back and forth.
    • Once aligned reinsert the toothed slider at the exact point shown.
  13. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning, VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 13, image 1 of 2 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning, VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 13, image 2 of 2
    • Lift the assembly to gain access to the connection point under the assembly.
  14. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 14, image 1 of 2 VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 14, image 2 of 2
    • Remove the two 7.5 mm screws with a Phillips #0 screwdriver.
  15. VTech Touch and Swipe Baby Phone Touchscreen Contact Cleaning: step 15, image 1 of 1
    • With the connector removed, clean both of the boxed sections with rubbing alcohol on a cotton swab. Allow a minute for the alcohol to dry before reassembling.
3 other people completed this guide.
Sean Webb
384 Reputation
2 Guides authored
USF Tampa, Team 2-4, Sullivan Fall 2015 Member of USF Tampa, Team 2-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G4
3 Members
12 Guides authored
5 Comments
Before I attempt this: Does this address the problem of the touch screen no longer responding and the device playing the same sound repeatedly?
Lars Gilbert - Reply
Well, the answer to my own question is “no”.
What if the unit is only 1 week old. Unlikely to be contact cleaning issues
Jason Chu - Reply
@larsgilbert did you find a fix to your problem? I have the same problem!
Dany - Reply
Regrettably, no.
Lars Gilbert -
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 24
All Time: 5,686
