VTech VM3254 Battery Replacement
  1. VTech VM3254 Battery Replacement, Battery: step 1, image 1 of 2 VTech VM3254 Battery Replacement, Battery: step 1, image 2 of 2
    • Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
  2. VTech VM3254 Battery Replacement: step 2, image 1 of 3 VTech VM3254 Battery Replacement: step 2, image 2 of 3 VTech VM3254 Battery Replacement: step 2, image 3 of 3
    • Use the iFixit Jimmy tool to begin removing the face of the monitor.
    • You may need to use an opening pick to hold the screen open as you move the Jimmy tool around all the edges of the device.
    • Once the screen has been separated, lift it from the case.
    • Be gentle while removing the screen. There are wires connected to the two pieces that may be damaged.
  3. VTech VM3254 Battery Replacement: step 3, image 1 of 2 VTech VM3254 Battery Replacement: step 3, image 2 of 2
    • Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
    • Remove the bracket.
  4. VTech VM3254 Battery Replacement: step 4, image 1 of 3 VTech VM3254 Battery Replacement: step 4, image 2 of 3 VTech VM3254 Battery Replacement: step 4, image 3 of 3
    • Gently remove the battery from its location.
    • Carefully disconnect the bundled cable connector from the circuit board.
Jackson Meacham
109 Reputation
1 Guide authored
1 Guide Comment
What is the battery that needs to be replaced called?
Aden Brooks - Reply
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 40
All Time: 2,460
