VTech Write and Learn Creative Center Slider Replacement
  1. VTech Write and Learn Creative Center Slider Replacement, Back Panel: step 1, image 1 of 3 VTech Write and Learn Creative Center Slider Replacement, Back Panel: step 1, image 2 of 3 VTech Write and Learn Creative Center Slider Replacement, Back Panel: step 1, image 3 of 3
    • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
  2. VTech Write and Learn Creative Center Slider Replacement, Slider: step 2, image 1 of 1
    • Remove the two 7mm PH 0 Phillips screws holding the slider to the slider handle.
    • The back of the slider will likely be coated in lubricant. Be careful not to make a mess.
Philip Zietkowski
342 Reputation
2 Guides authored
One Comment
This helps me alot. I haven't took my son's apart yet but my question is when you turn the slider to erase the board it will not erase. Do you think I will need to reattach something or is this fixable if take it apart? My email is caitlinmanderson0@gmail.com if you could kindly email me with any tips.
caitlin28901 - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 426
