Valve Index Controller Right Hand Strap Replacement
  1. Valve Index Controller Right Hand Strap Replacement, Remove the elastic band: step 1, image 1 of 3 Valve Index Controller Right Hand Strap Replacement, Remove the elastic band: step 1, image 2 of 3 Valve Index Controller Right Hand Strap Replacement, Remove the elastic band: step 1, image 3 of 3
    • Press and hold the elastic band adjustment button.
    • Slide the elastic band out of the controller.
    • During reassembly, pinch the elastic band near the tip of the loop and slide it into the controller.
  2. Valve Index Controller Right Hand Strap Replacement, Insert an opening pick: step 2, image 1 of 3 Valve Index Controller Right Hand Strap Replacement, Insert an opening pick: step 2, image 2 of 3 Valve Index Controller Right Hand Strap Replacement, Insert an opening pick: step 2, image 3 of 3
    • Insert an opening pick under the round plastic cover next to the A and B buttons.
    • Do not insert the opening pick more than 5 mm (0.2 in) into the controller, or you may tear the touchpad ribbon cable.
    • Slide the opening pick around the top of the controller until all three plastic clips are disengaged.
  3. Valve Index Controller Right Hand Strap Replacement, Open the controller: step 3, image 1 of 2 Valve Index Controller Right Hand Strap Replacement, Open the controller: step 3, image 2 of 2
    • Carefully open the top of the controller to access the screws inside.
    • Be careful not to strain or tear the ribbon cable connected to the touchpad.
  4. Valve Index Controller Right Hand Strap Replacement, Unscrew the adjustment strap: step 4, image 1 of 2 Valve Index Controller Right Hand Strap Replacement, Unscrew the adjustment strap: step 4, image 2 of 2
    • Use a T5 Torx screwdriver to remove the two 6.1 mm screws securing the adjustment strap to the controller.
    • Once the adjustment strap is unscrewed, the spring underneath may fall out.
    • Make sure the spring is installed during reassembly, or the ratcheted adjustment mechanism will not work properly.
  5. Valve Index Controller Right Hand Strap Replacement, Remove the adjustment strap: step 5, image 1 of 2 Valve Index Controller Right Hand Strap Replacement, Remove the adjustment strap: step 5, image 2 of 2
    • Slide the adjustment strap out from the controller to remove it.
    • If the spring falls, out, you'll need to reseat it for the adjustment mechanism to work. The spring should be located underneath the lip of the screwed-in part of the strap so that it can push against the mechanism when you push the strap in.
    • First, loosely screw the strap back in. Don't screw it in too tight, or you'll have trouble getting the spring in. Once it's screwed in, adjust the mechanism so that it's lined up with one of the pegs.
    • Place the spring so that the coil is around the nearby spoke, and the lower arm is seated in its little notch behind the strap screws.
    • You may want to use a magnetic screwdriver to seat the spring to prevent it from falling into the controller.
    • Put pressure on the coil of the spring so that it doesn't fly out, and move the arm of the spring over the top of the fastener, and push it in so that it stays underneath the lip.
    • While keeping pressure on the coil, quickly tighten the screws. Tighten the screw closest to the spring first. This will prevent the spring from unseating itself and springing back out.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
3 other people completed this guide.
Sam Omiotek
94,576 Reputation
290 Guides authored
3 Guide Comments
This guide doesn't go any detail on replacing the spring that is prone to flying out during the strap replacement. I offer anyone who attempts this repair luck and a cautionary tale: even with the photos and a working controller to compare it to, I was unable to tension the spring correctly or find the correct procedure for replacing it. The spring was too small for me to properly manipulate, and I ended up losing it in the controller casing.
I appreciate Sam putting this guide together, but not having instructions on replacing the spring on reinstall was a mistake that might cost me a couple hundred dollars. Please consider updating this guide.
ChaosMarine - Reply
I'm a few months late, but just in case I figured I'd toss a reply just in case you were interested in the imgur guide I made to help out anyone else struggling with this. It's posted as a separate comment on this post. Hope your repair went well otherwise!
VaporStrike -
I appreciate the guide, but as someone noted above, you are seriously lacking in the spring instructions, which might be the most important part of this assembly. However, I managed to find a way to get the spring seated back in on my own, and so for any other unfortunates stumbling onto this guide, I made my own crappy Imgur gallery guide for re-seating the spring. Each image has a small paragraph beneath it explaining the steps to take. I hope it manages to help anyone else struggling to swap out a strap.
https://imgur.com/gallery/RQYtS5e
VaporStrike - Reply
Past 24 Hours: 7
Past 7 Days: 59
Past 30 Days: 265
All Time: 14,126
