Velocity NoteMagix M10 A82 Battery Replacement
  1. Velocity NoteMagix M10 A82 Battery Replacement, Battery: step 1, image 1 of 2 Velocity NoteMagix M10 A82 Battery Replacement, Battery: step 1, image 2 of 2
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Velocity NoteMagix M10 A82 Battery Replacement: step 2, image 1 of 2 Velocity NoteMagix M10 A82 Battery Replacement: step 2, image 2 of 2
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
Sam Middleton
401 Reputation
4 Guides authored
Cal Poly, Team 14-9, Forte Fall 2013 Member of Cal Poly, Team 14-9, Forte Fall 2013
CPSU-FORTE-F13S14G9
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 494
