Velocity NoteMagix M10 A82 DDR RAM Replacement
  1. Velocity NoteMagix M10 A82 DDR RAM Replacement, Battery: step 1, image 1 of 2 Velocity NoteMagix M10 A82 DDR RAM Replacement, Battery: step 1, image 2 of 2
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Velocity NoteMagix M10 A82 DDR RAM Replacement: step 2, image 1 of 2 Velocity NoteMagix M10 A82 DDR RAM Replacement: step 2, image 2 of 2
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. Velocity NoteMagix M10 A82 DDR RAM Replacement, RAM: step 3, image 1 of 2 Velocity NoteMagix M10 A82 DDR RAM Replacement, RAM: step 3, image 2 of 2
    • Locate the DDR panel and unscrew the two 3.65mm Phillips #1 screws holding it in place.
    • Use the spudger to lift the DDR panel off.
  4. Velocity NoteMagix M10 A82 DDR RAM Replacement: step 4, image 1 of 3 Velocity NoteMagix M10 A82 DDR RAM Replacement: step 4, image 2 of 3 Velocity NoteMagix M10 A82 DDR RAM Replacement: step 4, image 3 of 3
    • Push in the tabs on the sides that contain the RAM.
    • Gently raise the RAM up to a 45 degree angle and gently pull the RAM towards you.
Sam Middleton
401 Reputation
4 Guides authored
Cal Poly, Team 14-9, Forte Fall 2013 Member of Cal Poly, Team 14-9, Forte Fall 2013
CPSU-FORTE-F13S14G9
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 366
