Verizon Ellipsis 10 Camera Replacement
  1. Verizon Ellipsis 10 Camera Replacement, Back Cover: step 1, image 1 of 1
    • Open the SD/SIM card cover to start prying off the back cover.
  2. Verizon Ellipsis 10 Camera Replacement: step 2, image 1 of 1
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
  3. Verizon Ellipsis 10 Camera Replacement: step 3, image 1 of 1
    • Follow along the edge of the device to undo all of the retaining clips.
  4. Verizon Ellipsis 10 Camera Replacement: step 4, image 1 of 1
    • Once all the clips are undone, the back panel should come off with little effort.
  5. Verizon Ellipsis 10 Camera Replacement, Battery: step 5, image 1 of 1
    • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
  6. Verizon Ellipsis 10 Camera Replacement: step 6, image 1 of 1
    • Remove the top piece of tape using an iFixit opening tool.
  7. Verizon Ellipsis 10 Camera Replacement: step 7, image 1 of 1
    • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
  8. Verizon Ellipsis 10 Camera Replacement: step 8, image 1 of 1
    • Unplug the battery power connector by sliding the white plastic plug down away from the board.
  9. Verizon Ellipsis 10 Camera Replacement: step 9, image 1 of 1
    • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
  10. Verizon Ellipsis 10 Camera Replacement, Camera: step 10, image 1 of 1
    • Remove 4 M1.5 screws holding in the labeled LTE module.
  11. Verizon Ellipsis 10 Camera Replacement: step 11, image 1 of 1
    • Use a nylon spudger to pry up the module.
    • It's held in with some clips so there will be a little bit of resistance.
  12. Verizon Ellipsis 10 Camera Replacement: step 12, image 1 of 2 Verizon Ellipsis 10 Camera Replacement: step 12, image 2 of 2
    • Remove the 4 M1.5 screws holding in the labeled auxiliary LTE/GPS module.
    • The module should come up with a little resistance.
  13. Verizon Ellipsis 10 Camera Replacement: step 13, image 1 of 1
    Tool used on this step:
    Buy
    • Use a pair of tweezers to lift up the front camera off its locating post.
  14. Verizon Ellipsis 10 Camera Replacement: step 14, image 1 of 2 Verizon Ellipsis 10 Camera Replacement: step 14, image 2 of 2
    • Remove the non-conductive tape covering the camera ribbon cable.
    • You may need to remove the white antenna cable to remove the tape.
  15. Verizon Ellipsis 10 Camera Replacement: step 15, image 1 of 1
    • Carefully unplug the ribbon cable from the motherboard.
  16. Verizon Ellipsis 10 Camera Replacement: step 16, image 1 of 2 Verizon Ellipsis 10 Camera Replacement: step 16, image 2 of 2
    • Peel up the ribbon cable carefully as it is glued to the device.
    • After having peeled up the cable, the cameras should be free to come out of the device.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 219
