Verizon Ellipsis 10 WiFi Module Replacement
  1. Verizon Ellipsis 10 WiFi Module Replacement, Back Cover: step 1, image 1 of 1
    • Open the SD/SIM card cover to start prying off the back cover.
  2. Verizon Ellipsis 10 WiFi Module Replacement: step 2, image 1 of 1
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
  3. Verizon Ellipsis 10 WiFi Module Replacement: step 3, image 1 of 1
    • Follow along the edge of the device to undo all of the retaining clips.
  4. Verizon Ellipsis 10 WiFi Module Replacement: step 4, image 1 of 1
    • Once all the clips are undone, the back panel should come off with little effort.
  5. Verizon Ellipsis 10 WiFi Module Replacement, WiFi Module: step 5, image 1 of 1
    • Locate Wi-Fi module in bottom right-hand corner.
  6. Verizon Ellipsis 10 WiFi Module Replacement: step 6, image 1 of 1
    • Unscrew the M1.5 screw using a Phillips #00 screwdriver.
  7. Verizon Ellipsis 10 WiFi Module Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Using a pair of tweezers or needle nose pliers, pull up the connecting wire.
    • Lift the module out.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 322
