Verizon Ellipsis 7 Battery Replacement
  1. Verizon Ellipsis 7 Battery Replacement, Battery: step 1, image 1 of 3 Verizon Ellipsis 7 Battery Replacement, Battery: step 1, image 2 of 3 Verizon Ellipsis 7 Battery Replacement, Battery: step 1, image 3 of 3
    • Power down device by holding down the power button until the screen goes black.
    • Remove the SIM card from the device to prevent damage.
    • To remove the SIM card, open the SIM card cover on the side of the device.
    • Push SIM card in and then pull out after hearing a click.
  2. Verizon Ellipsis 7 Battery Replacement: step 2, image 1 of 2 Verizon Ellipsis 7 Battery Replacement: step 2, image 2 of 2
    • Take off the back panel.
    • Pry open the back cover carefully with a plastic opening tool.
    • Use the opening tool to disconnect the cover completely. Do not attempt to pull the back cover off with your hands.
    • Be sure to pry open all sides of the device. Attempting to take off the back cover when part of it is attached may snap the cover.
  3. Verizon Ellipsis 7 Battery Replacement: step 3, image 1 of 3 Verizon Ellipsis 7 Battery Replacement: step 3, image 2 of 3 Verizon Ellipsis 7 Battery Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the charging (micro-USB) port by unscrewing the indicated screws using the Phillips #00 screwdriver.
    • Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
    • Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
    • Be extremely careful when disconnecting the ribbon cable. It is very delicate.
11 other people completed this guide.
Scott Mangin
609 Reputation
2 Guides authored
Cal Poly, Team 13-5, Banghart Winter 2017 Member of Cal Poly, Team 13-5, Banghart Winter 2017
CPSU-BANGHART-W17S13G5
4 Members
4 Guides authored
8 Guide Comments
so much for the charging port. You didn’t mention the battery. ?
good1946scout - Reply
Well….ok…..but were we here for removing the charging port? Ha ha….I think not. So how about we lift out the battery and unplug it instead. Takes a bit of effort , it seems. That sucker is stuck down pretty good with some really good double sided tape. Lift carefully. I pried it up with the same plastic case tool I used to remove the back cover. The same tool also helped me remove the battery plug.
David Shaw - Reply
First time on Ifixit and they leave me two steps from the goal; not much of a confidence-builder for this site!
Groove - Reply
WTH? Replacing the battery?
kaycha12 - Reply
Look at the stats..
Why suddenly are so many units failing at or about the same time? I'm not a conspirist but,
Don't you think it's a strange coincidence?
Kermit Allison - Reply
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 31
All Time: 30,242
