Verizon Ellipsis 7 Speaker Replacement
  1. Verizon Ellipsis 7 Speaker Replacement, Charging Port: step 1, image 1 of 3 Verizon Ellipsis 7 Speaker Replacement, Charging Port: step 1, image 2 of 3 Verizon Ellipsis 7 Speaker Replacement, Charging Port: step 1, image 3 of 3
    • Hold down the power button until the screen goes black to turn off the device.
    • Remove the SIM card from the device to prevent damage.
    • To remove the SIM card, open the SIM card cover on the side of the device.
    • Push SIM card in and pull it out after hearing a click.
  2. Verizon Ellipsis 7 Speaker Replacement: step 2, image 1 of 2 Verizon Ellipsis 7 Speaker Replacement: step 2, image 2 of 2
    • Take off the back panel.
    • Pry open the back cover carefully with a plastic opening tool.
    • Use the opening tool to disconnect the cover completely. Do not attempt to pry the back cover off with your hands.
    • Be sure to pry open all sides of the device. Attempting to take off the back cover when part of it is attached may snap the cover.
  3. Verizon Ellipsis 7 Speaker Replacement: step 3, image 1 of 3 Verizon Ellipsis 7 Speaker Replacement: step 3, image 2 of 3 Verizon Ellipsis 7 Speaker Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the charging (micro-USB) port.
    • Unscrew the indicated screws using the Phillips #00 screwdriver.
    • The screws shown in the picture are the more common 4.76 mm.
    • Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
    • Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
    • Be extremely careful when disconnecting the ribbon cable. It is very delicate.
  4. Verizon Ellipsis 7 Speaker Replacement: step 4, image 1 of 2 Verizon Ellipsis 7 Speaker Replacement: step 4, image 2 of 2
    • Remove the charging port board from the phone using tweezers.
    • Place the replacement charging port into the phone.
    • Be cautious when replacing the ribbon cable onto the new charging port board.
  5. Verizon Ellipsis 7 Speaker Replacement, Speaker: step 5, image 1 of 2 Verizon Ellipsis 7 Speaker Replacement, Speaker: step 5, image 2 of 2
    • Remove 2 screws from each speaker, 4 screws in total, using a Phillips #00 screwdriver.
  6. Verizon Ellipsis 7 Speaker Replacement: step 6, image 1 of 3 Verizon Ellipsis 7 Speaker Replacement: step 6, image 2 of 3 Verizon Ellipsis 7 Speaker Replacement: step 6, image 3 of 3
    Buy
    • Using tweezers carefully lift the connector up to disconnect it from the motherboard.
    • Using tweezers carefully pull the speakers up and out of device.
2 other people completed this guide.
Charles Gorbett
242 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,182
