Verizon Ellipsis 8 Screen Replacement
  1. Verizon Ellipsis 8 Screen Replacement, Battery: step 1, image 1 of 1
    • Using a plastic opening tool, slowly pry along the seam running along the edge of the device until the back case snaps free.
    • Remove the back case.
  2. Verizon Ellipsis 8 Screen Replacement: step 2, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the two 0.1 mm screws on the green bracket.
  3. Verizon Ellipsis 8 Screen Replacement: step 3, image 1 of 1
    • Once you remove the backing of the Verizon Ellipsis 8, gently use the spudger to lift one side of the tape. Once you have lifted the tape, slowly remove it until it is completely off the battery.
  4. Verizon Ellipsis 8 Screen Replacement: step 4, image 1 of 1
    • Lift and remove the battery from the device.
  5. Verizon Ellipsis 8 Screen Replacement, Speaker: step 5, image 1 of 3 Verizon Ellipsis 8 Screen Replacement, Speaker: step 5, image 2 of 3 Verizon Ellipsis 8 Screen Replacement, Speaker: step 5, image 3 of 3
    • Remove all 5 screws from their respective holes using the Phillips #00 screwdriver.
    • Remove the speaker from the device.
  6. Verizon Ellipsis 8 Screen Replacement, Screen: step 6, image 1 of 1
    • Using a guitar pick or a metal spudger, remove the old screen from the device from the back of the tablet.
Sreedhar Kesari
190 Reputation
2 Guides authored
IUPUI, Team S2-G2, Stella Fall 2019 Member of IUPUI, Team S2-G2, Stella Fall 2019
IUPUI-STELLA-F19S2G2
4 Members
2 Guides authored
1 Guide Comment
This guide is incomplete, with several steps and details omitted.
As it is now, this guide is inadequate for anyone who has never done anything like this before. Yet it's also almost completely unnecessary for anyone with a little experience doing similar repairs.
So, it's of almost no use to anyone!
ajfranzman - Reply
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 43
All Time: 1,277
