Verizon M1424WR Capacitor Replacement
  1. Verizon M1424WR Capacitor Replacement, Motherboard: step 1, image 1 of 1
    • Flip the device so that the bottom is facing up.
  2. Verizon M1424WR Capacitor Replacement: step 2, image 1 of 3 Verizon M1424WR Capacitor Replacement: step 2, image 2 of 3 Verizon M1424WR Capacitor Replacement: step 2, image 3 of 3
    • Warning: The design and location of the plastic clips holding this shroud make it extremely difficult to release. Take your time and use a second pry tool if necessary.
    • Insert the plastic-opening tool under the silver labeled casing.
    • Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
  3. Verizon M1424WR Capacitor Replacement: step 3, image 1 of 2 Verizon M1424WR Capacitor Replacement: step 3, image 2 of 2
    • Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
  4. Verizon M1424WR Capacitor Replacement: step 4, image 1 of 2 Verizon M1424WR Capacitor Replacement: step 4, image 2 of 2
    • Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
  5. Verizon M1424WR Capacitor Replacement: step 5, image 1 of 3 Verizon M1424WR Capacitor Replacement: step 5, image 2 of 3 Verizon M1424WR Capacitor Replacement: step 5, image 3 of 3
    • Locate the two 10-mm screws on either side of the circuit board.
    • Unscrew the two 10-mm screws using a Phillips #0 screwdriver.
    • Keep track of the red rubber washer you remove from underneath one of the screws.
  6. Verizon M1424WR Capacitor Replacement: step 6, image 1 of 1
    • Lift the front of the circuit board up from the bottom casing.
  7. Verizon M1424WR Capacitor Replacement: step 7, image 1 of 1
    • Pull the circuit board towards you until it is separate from the bottom casing.
  8. Verizon M1424WR Capacitor Replacement, Capacitor: step 8, image 1 of 1
    • Locate the capacitor.
  9. Verizon M1424WR Capacitor Replacement: step 9, image 1 of 1
    • Flip the circuit board over.
    • Locate the two prongs on the flip side that are attached to the capacitor on the top side.
  10. Verizon M1424WR Capacitor Replacement: step 10, image 1 of 3 Verizon M1424WR Capacitor Replacement: step 10, image 2 of 3 Verizon M1424WR Capacitor Replacement: step 10, image 3 of 3
    • Touch the hot soldering iron to each prong in order to melt the solder around them.
    • Flip the circuit board and pull out the capacitor from its place while the solder is still hot.
    • For help with soldering techniques, click here.
  11. Verizon M1424WR Capacitor Replacement, Reassembly: step 11, image 1 of 3 Verizon M1424WR Capacitor Replacement, Reassembly: step 11, image 2 of 3 Verizon M1424WR Capacitor Replacement, Reassembly: step 11, image 3 of 3
    • Insert the new capacitor through the circuit board so that the prongs are exposed on the flip side.
    • Heat the prongs up with the soldering iron and touch a soldering wire to the hot prongs to attach the capacitor to the board.
To reassemble your device, follow Steps 1-7 in reverse order.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 727
