Verizon M1424WR Motherboard Replacement
  1. Verizon M1424WR Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Flip the device so that the bottom is facing up.
  2. Verizon M1424WR Motherboard Replacement: step 2, image 1 of 3 Verizon M1424WR Motherboard Replacement: step 2, image 2 of 3 Verizon M1424WR Motherboard Replacement: step 2, image 3 of 3
    • Warning: The design and location of the plastic clips holding this shroud make it extremely difficult to release. Take your time and use a second pry tool if necessary.
    • Insert the plastic-opening tool under the silver labeled casing.
    • Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
  3. Verizon M1424WR Motherboard Replacement: step 3, image 1 of 2 Verizon M1424WR Motherboard Replacement: step 3, image 2 of 2
    • Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
  4. Verizon M1424WR Motherboard Replacement: step 4, image 1 of 2 Verizon M1424WR Motherboard Replacement: step 4, image 2 of 2
    • Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
  5. Verizon M1424WR Motherboard Replacement: step 5, image 1 of 3 Verizon M1424WR Motherboard Replacement: step 5, image 2 of 3 Verizon M1424WR Motherboard Replacement: step 5, image 3 of 3
    • Locate the two 10-mm screws on either side of the circuit board.
    • Unscrew the two 10-mm screws using a Phillips #0 screwdriver.
    • Keep track of the red rubber washer you remove from underneath one of the screws.
  6. Verizon M1424WR Motherboard Replacement: step 6, image 1 of 1
    • Lift the front of the circuit board up from the bottom casing.
  7. Verizon M1424WR Motherboard Replacement: step 7, image 1 of 1
    • Pull the circuit board towards you until it is separate from the bottom casing.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 785
