Verizon M1424WR Refresh Button Replacement
  1. Verizon M1424WR Refresh Button Replacement, Refresh Button: step 1, image 1 of 1
    • Flip the device so that the bottom is facing up.
  2. Verizon M1424WR Refresh Button Replacement: step 2, image 1 of 3 Verizon M1424WR Refresh Button Replacement: step 2, image 2 of 3 Verizon M1424WR Refresh Button Replacement: step 2, image 3 of 3
    • Insert the plastic-opening tool under the silver labeled casing.
    • Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
  3. Verizon M1424WR Refresh Button Replacement: step 3, image 1 of 2 Verizon M1424WR Refresh Button Replacement: step 3, image 2 of 2
    • Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
  4. Verizon M1424WR Refresh Button Replacement: step 4, image 1 of 2 Verizon M1424WR Refresh Button Replacement: step 4, image 2 of 2
    • Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
  5. Verizon M1424WR Refresh Button Replacement: step 5, image 1 of 1
    • Locate the refresh button.
  6. Verizon M1424WR Refresh Button Replacement: step 6, image 1 of 3 Verizon M1424WR Refresh Button Replacement: step 6, image 2 of 3 Verizon M1424WR Refresh Button Replacement: step 6, image 3 of 3
    • Apply pressure with your finger to the black tab that retains the refresh button while using your other hand to pull the bottom of the refresh button from the post.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 449
