VersaMed iVent 201 On/Off Switch Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. VersaMed iVent 201 On/Off Switch Replacement, On/Off Switch: step 1, image 1 of 1
    • Use a pair of slim pliers or tweezers to grip the cap of the power switch button. Pull it straight out.
  2. VersaMed iVent 201 On/Off Switch Replacement: step 2, image 1 of 1
    • Examine the exposed area and look for a gray, metallic ring. If it is present, use the pliers or tweezers to remove it. If no ring is found, skip this step.
  3. VersaMed iVent 201 On/Off Switch Replacement: step 3, image 1 of 1
    • For reinstallation, locate the white dot on the exposed surface, and line this dot up with the slot in the middle of the button. Press the button straight in.
Miriam Miller
678 Reputation
4 Guides authored
Cal Poly, Team 2-1, Johann Winter 2023 Member of Cal Poly, Team 2-1, Johann Winter 2023
CPSU-JOHANN-W23S2G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 170
