Vertical Blind Slat Replacement
  1. Vertical Blind Slat Replacement, Slat: step 1, image 1 of 2 Vertical Blind Slat Replacement, Slat: step 1, image 2 of 2
    • Remove the old slat by lifting it upwards.
  2. Vertical Blind Slat Replacement: step 2, image 1 of 2 Vertical Blind Slat Replacement: step 2, image 2 of 2
    • Once lifted, gently pull the slat toward you to remove it completely from the clip.
  3. Vertical Blind Slat Replacement: step 3, image 1 of 1
    • Adjust and ensure the curve of the new slat is facing the same direction as the other old slats.
  4. Vertical Blind Slat Replacement: step 4, image 1 of 1
    • Slide the new slat upwards into the first clip.
  5. Vertical Blind Slat Replacement: step 5, image 1 of 1
    • Continue sliding the slat upwards until it clicks into place in the second clip.
  6. Vertical Blind Slat Replacement: step 6, image 1 of 1
    • Once finished, gently pull the slat toward you to ensure it is securely attached.
Finish Line
KA YEE LUI
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 36
All Time: 390
