Viasys Avea Metal Top Cover Disassembly
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Viasys Avea Metal Top Cover Disassembly, Viasys Avea UIM and Plastic Cover Disassembly: step 1, image 1 of 1
    • Remove the ‘rubber collar’ located at the UIM rear neck, by grasping one of the two rubber tabs at the bottom. Pull firmly in an “arcing” motion.
    • Pull UIM forward and look for the Phillips Screw on the front arm cover. Remove (1) Phillips screw from the front arm cover. Remove the front arm cover.
    • Remove the two mounting screws now visible inside the ‘back arm cover’. Tilt the UIM down and remove the ‘back arm cover’.
  2. Viasys Avea Metal Top Cover Disassembly: step 4, image 1 of 1
    • Remove the (4) 11/32 KEP nuts that secure the ‘plastic top cover’ opening onto the chassis.
    • Remove (2) Phillips screws that secure the ‘plastic top cover’ to the rear chassis.
    • Slide the top ‘plastic top cover’ upward and forward away from the chassis.
    • Remove the (2) Phillips screws and washers that secure the HSSC Cable on the GDE. Unplug the HSSC Cable.
    • Carefully feed the HSSC Cable through the ‘plastic top cover’ opening.
    • While continuously supporting the UIM, remove (4) 3/8 nuts that fasten the UIM support arm onto the pneumatics.
    • Lift UIM off of pneumatics and set aside.
    • Remove plastic cover and set aside.
    • Check to see if the exhalation filter assembly is installed, if it is, remove the exhalation filter assembly.
    • Rotate the metal locking lever on the lower right of the ventilator body forward to an open position.
    • Remove the exhalation filter assembly from the ventilator body by pulling straight down.
    • Using a long Phillips screwdriver, remove the Phillips screw located at the top of the exhalation filter assembly well, if applicable.
    • Using a long Phillips screwdriver, remove the Phillips screw located at the exhalation port marked EXH, if applicable.
    • Using a long Phillips screwdriver, remove the Phillips screw from the outside of the plastic cover.
    • Using a long Phillips screwdriver, remove the Phillips screw on the font left wall.
    • Using a long Phillips screwdriver, remove the Phillips screw on the right side of the wall.
    • Set the plastic cover aside.
    • Using a long Phillips screwdriver, remove the 3 Phillips screws on the metal re-enforcement cover, if applicable, and set aside.
    • Remove the Exhalation Corner Assembly.
    • Locate metal top cover
    • Remove the 19 SEMS screws, (3) on the left side (5) on the right sife and (11) on top.
    • Remove metal top cover and set aside.
    • Disconnect the internal battery 2 pin Molex connector
Anthony Hernandez
394 Reputation
3 Guides authored
Cal Poly, Team S1-G1, Zimmerman Spring 2020 Member of Cal Poly, Team S1-G1, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G1
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 125
