Vicks FilterFree Plus Fan Replacement
  1. Vicks FilterFree Plus Fan Replacement, Tank Cap: step 1, image 1 of 1
    • Ensure the device is clear of water before disassembling.
    • Orient the device so the nozzle is facing the ceiling.
    • Twist off the primary water holding cap.
  2. Vicks FilterFree Plus Fan Replacement: step 2, image 1 of 2 Vicks FilterFree Plus Fan Replacement: step 2, image 2 of 2
    • Place the device upside down so that the tank cap is facing you.
    • Use your hands to twist the tank cap and remove it from the device.
  3. Vicks FilterFree Plus Fan Replacement, Fan: step 3, image 1 of 2 Vicks FilterFree Plus Fan Replacement, Fan: step 3, image 2 of 2
    • Remove the three screws from the base of the device using a T20 Torx screwdriver.
    • Remove the base of the humidifier to access the components.
  4. Vicks FilterFree Plus Fan Replacement: step 4, image 1 of 2 Vicks FilterFree Plus Fan Replacement: step 4, image 2 of 2
    • Gently remove the inner shield for the primary board to access the wiring for the humidifier.
  5. Vicks FilterFree Plus Fan Replacement: step 5, image 1 of 3 Vicks FilterFree Plus Fan Replacement: step 5, image 2 of 3 Vicks FilterFree Plus Fan Replacement: step 5, image 3 of 3
    • Remove the fan by disconnecting its wire from the board.
    • Gently remove the fan from the device.
Logan Pianfetti
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 38
Past 30 Days: 111
All Time: 1,279
