Vicks FilterFree Plus Power Cord Replacement
  1. Vicks FilterFree Plus Power Cord Replacement, Tank Cap: step 1, image 1 of 1
    • Ensure the device is clear of water before disassembling.
    • Orient the device so the nozzle is facing the ceiling.
    • Twist off the primary water holding cap.
  2. Vicks FilterFree Plus Power Cord Replacement: step 2, image 1 of 2 Vicks FilterFree Plus Power Cord Replacement: step 2, image 2 of 2
    • Place the device upside down so that the tank cap is facing you.
    • Use your hands to twist the tank cap and remove it from the device.
  3. Vicks FilterFree Plus Power Cord Replacement, Power Cord: step 3, image 1 of 2 Vicks FilterFree Plus Power Cord Replacement, Power Cord: step 3, image 2 of 2
    • Remove the three screws from the base of the device using a T20 Torx screwdriver.
    • Remove the base of the humidifier to access the components.
  4. Vicks FilterFree Plus Power Cord Replacement: step 4, image 1 of 2 Vicks FilterFree Plus Power Cord Replacement: step 4, image 2 of 2
    • Gently remove the inner shield for the primary board to access the wiring for the humidifier.
  5. Vicks FilterFree Plus Power Cord Replacement: step 5, image 1 of 3 Vicks FilterFree Plus Power Cord Replacement: step 5, image 2 of 3 Vicks FilterFree Plus Power Cord Replacement: step 5, image 3 of 3
    • Remove the two Phillips screws holding the power cord in place.
    • Unclip the power cord from the motherboard.
NathanBatista021
497 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 165
