Violin Strings Replacement
  1. Violin Strings Replacement, Strings: step 1, image 1 of 2 Violin Strings Replacement, Strings: step 1, image 2 of 2
    • Turn the peg belonging to the string you are wanting to change to loosen the string.
    • Violins have four string. The strings from left to right go: G, D, A, & E.
  2. Violin Strings Replacement: step 2, image 1 of 1
    • Pull the string out of the peg.
  3. Violin Strings Replacement: step 3, image 1 of 2 Violin Strings Replacement: step 3, image 2 of 2
    • Remove the opposite end of the string from the fine tuner holder.
  4. Violin Strings Replacement: step 4, image 1 of 2 Violin Strings Replacement: step 4, image 2 of 2
    • Place new string in peg hole.
  5. Violin Strings Replacement: step 5, image 1 of 1
    • Turn the peg to tighten the string.
  6. Violin Strings Replacement: step 6, image 1 of 2 Violin Strings Replacement: step 6, image 2 of 2
    • Place nub in fine tuner holder.
  7. Violin Strings Replacement: step 7, image 1 of 1
    • Make sure the string is sitting in the groove in the bridge.
  8. Violin Strings Replacement: step 8, image 1 of 1
    • Gently tug on string to make sure it is secure.
5 other people completed this guide.
Brittany Preston
245 Reputation
1 Guide authored
1 Guide Comment
Thanks for this very clear set of instructions with clear images. I am an amateur violinist and broke a string while tuning. Even I could use these instructions and it was as easy as the post says. Thanks for posting and to ifixit in general.
Svasangana jeevi - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 39
All Time: 15,858
