Visioneer OneTouch 7400 USB Outer Case Replacement
  1. Visioneer OneTouch 7400 USB Outer Case Replacement, Outer Case: step 1, image 1 of 1
    • On the bottom of the scanner, remove the screw at the top left side.
  2. Visioneer OneTouch 7400 USB Outer Case Replacement: step 2, image 1 of 2 Visioneer OneTouch 7400 USB Outer Case Replacement: step 2, image 2 of 2
    • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
    • Remove the screw beneath the foot-pad.
  3. Visioneer OneTouch 7400 USB Outer Case Replacement: step 3, image 1 of 3 Visioneer OneTouch 7400 USB Outer Case Replacement: step 3, image 2 of 3 Visioneer OneTouch 7400 USB Outer Case Replacement: step 3, image 3 of 3
    • Rotate the scanner so the screw hole is located on the top left hand side.
    • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
    • Gently pry the two casements apart beginning above the screw hole and working your way around.
    • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
  4. Visioneer OneTouch 7400 USB Outer Case Replacement: step 4, image 1 of 1
    • Separate the two casement pieces.
Jena
608 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 10
All Time: 311
