Vitamix 5200 Drive Socket Replacement
  1. Vitamix 5200 Drive Socket Replacement, Drive Socket: step 1, image 1 of 3 Vitamix 5200 Drive Socket Replacement, Drive Socket: step 1, image 2 of 3 Vitamix 5200 Drive Socket Replacement, Drive Socket: step 1, image 3 of 3
    • Unplug the motor from its external power source.
    • Remove the blender jar from the motor base.
  2. Vitamix 5200 Drive Socket Replacement: step 2, image 1 of 2 Vitamix 5200 Drive Socket Replacement: step 2, image 2 of 2
    • Lift up and remove the rubber jar pad surrounding the drive socket.
  3. Vitamix 5200 Drive Socket Replacement: step 3, image 1 of 2 Vitamix 5200 Drive Socket Replacement: step 3, image 2 of 2
    • Align the Vitamix logo and arrow to the small hole at the base of the drive socket.
  4. Vitamix 5200 Drive Socket Replacement: step 4, image 1 of 3 Vitamix 5200 Drive Socket Replacement: step 4, image 2 of 3 Vitamix 5200 Drive Socket Replacement: step 4, image 3 of 3
    • Using a 5/64th Allen wrench, place it at a 45-degree angle into the small hole and twist leftward to loosen the drive socket.
    • Only loosen to the point of freeing the socket. Loosen too much and you risk dropping the screw into the motor.
  5. Vitamix 5200 Drive Socket Replacement: step 5, image 1 of 2 Vitamix 5200 Drive Socket Replacement: step 5, image 2 of 2
    • Remove the old drive socket.
  6. Vitamix 5200 Drive Socket Replacement: step 6, image 1 of 3 Vitamix 5200 Drive Socket Replacement: step 6, image 2 of 3 Vitamix 5200 Drive Socket Replacement: step 6, image 3 of 3
    • Place the new drive socket on the square nut.
    • Realign the logo and arrow with the small hole at the sockets base.
  7. Vitamix 5200 Drive Socket Replacement: step 7, image 1 of 1
    • Twist the Allen wrench rightward to tighten the new drive socket into place.
2 other people completed this guide.
2 Guide Comments
Excelente explicativo. Normalmente a estos equipos hay que observar que las dos llaves estén en buenas condiciones, sobre todo el pulsador, la mayoría de las veces es el problema principal que el equipo funcione mal. Saludos EXITOS
Carlos Soto - Reply Share
Très pratique
Hamissou Nhour - Reply Share
Past 24 Hours: 7
Past 7 Days: 60
Past 30 Days: 245
All Time: 3,008
