Vivitar DVR 781HD Motherboard Replacement
  1. Vivitar DVR 781HD Motherboard Replacement, Front Case: step 1, image 1 of 3 Vivitar DVR 781HD Motherboard Replacement, Front Case: step 1, image 2 of 3 Vivitar DVR 781HD Motherboard Replacement, Front Case: step 1, image 3 of 3
    • Begin with the camcorder lens up on a clear working surface.
    • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
  2. Vivitar DVR 781HD Motherboard Replacement: step 2, image 1 of 1
    • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
  3. Vivitar DVR 781HD Motherboard Replacement: step 3, image 1 of 3 Vivitar DVR 781HD Motherboard Replacement: step 3, image 2 of 3 Vivitar DVR 781HD Motherboard Replacement: step 3, image 3 of 3
    • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
    • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
  4. Vivitar DVR 781HD Motherboard Replacement, Motherboard: step 4, image 1 of 2 Vivitar DVR 781HD Motherboard Replacement, Motherboard: step 4, image 2 of 2
    • Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
  5. Vivitar DVR 781HD Motherboard Replacement: step 5, image 1 of 1
    • Gently lift the motherboard, handling it by the edges.
2 other people completed this guide.
Nathan McDaniel
592 Reputation
3 Guides authored
IUPUI, Team 54-6, Wilson Spring 2016 Member of IUPUI, Team 54-6, Wilson Spring 2016
IUPUI-WILSON-S16S54G6
3 Members
10 Guides authored
3 Comments
It says no parts required, but it is instructions to replace the motherboard.
There is nothing about getting another motherboard, and how much.
Heki Kahni - Reply
How do you get a motherboard?
Rdam Russell - Reply
Where do we get one?
bikerbarbie29 - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 1,441
