Vivitar DVR 781HD Screen Replacement
  1. Vivitar DVR 781HD Screen Replacement, Front Case: step 1, image 1 of 3 Vivitar DVR 781HD Screen Replacement, Front Case: step 1, image 2 of 3 Vivitar DVR 781HD Screen Replacement, Front Case: step 1, image 3 of 3
    • Begin with the camcorder lens up on a clear working surface.
    • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
  2. Vivitar DVR 781HD Screen Replacement: step 2, image 1 of 1
    • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
  3. Vivitar DVR 781HD Screen Replacement: step 3, image 1 of 3 Vivitar DVR 781HD Screen Replacement: step 3, image 2 of 3 Vivitar DVR 781HD Screen Replacement: step 3, image 3 of 3
    • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
    • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
  4. Vivitar DVR 781HD Screen Replacement, Motherboard: step 4, image 1 of 2 Vivitar DVR 781HD Screen Replacement, Motherboard: step 4, image 2 of 2
    • Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
  5. Vivitar DVR 781HD Screen Replacement: step 5, image 1 of 1
    • Gently lift the motherboard, handling it by the edges.
  6. Vivitar DVR 781HD Screen Replacement, Screen: step 6, image 1 of 2 Vivitar DVR 781HD Screen Replacement, Screen: step 6, image 2 of 2
    • Remove the two 4mm Phillips #1 screws holding the screen assembly to the motherboard.
  7. Vivitar DVR 781HD Screen Replacement: step 7, image 1 of 2 Vivitar DVR 781HD Screen Replacement: step 7, image 2 of 2
    • Turn the motherboard and screen over.
    • Gently lift the screen from the motherboard, handling it by the edges of the black plastic holder.
  8. Vivitar DVR 781HD Screen Replacement: step 8, image 1 of 1
    • Using a soldering iron, melt the solder connection between the screen's ribbon cable and the motherboard. Pull the ribbon cable away before the solder solidifies.
2 other people completed this guide.
Nathan McDaniel
592 Reputation
3 Guides authored
IUPUI, Team 54-6, Wilson Spring 2016 Member of IUPUI, Team 54-6, Wilson Spring 2016
IUPUI-WILSON-S16S54G6
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 16
All Time: 608
