Vivitar DVR 781HD Waterproof Case Lens Cover Replacement
  1. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement, Waterproof Case Lens Cover: step 1, image 1 of 1
    • Place waterproof case on flat surface, with the lens cover facing up.
  2. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: step 2, image 1 of 2 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: step 2, image 2 of 2
    • Remove the six 4.5mm Phillips #00 screws from the black lens cover trim.
  3. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: step 3, image 1 of 2 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: step 3, image 2 of 2
    • While holding the black lens cover trim tight to the case, flip the case over so that the lens cover is rested on your work surface.
  4. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: step 4, image 1 of 2 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: step 4, image 2 of 2
    • Apply pressure to the lens cover with your thumb, and use your other fingers to pull up on the case, separating the lens and lens trim from the case.
  5. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: step 5, image 1 of 2 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: step 5, image 2 of 2
    • There is a small plastic key on the black bezel that aligns it to the case. Be sure to line this up during reassembly.
Jordan Baum
355 Reputation
2 Guides authored
IUPUI, Team 54-6, Wilson Spring 2016 Member of IUPUI, Team 54-6, Wilson Spring 2016
IUPUI-WILSON-S16S54G6
3 Members
10 Guides authored
One Comment
Hello, do you know where I can acquire a replacement water proof case for my Vivitar DVR 787 HD action camcorder?
Andrew Hinsley - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 1,269
