Vivitar XO 7 Motherboard Replacement
  1. Vivitar XO 7 Motherboard Replacement, Back Cover: step 1, image 1 of 1
    • Remove the two 3mm Phillips #00 screws on the bottom of the tablet.
  2. Vivitar XO 7 Motherboard Replacement: step 2, image 1 of 1
    • With the plastic opening tools, pry open the back cover.
  3. Vivitar XO 7 Motherboard Replacement: step 3, image 1 of 1
    • Remove the back cover from the tablet.
  4. Vivitar XO 7 Motherboard Replacement, Battery: step 4, image 1 of 2 Vivitar XO 7 Motherboard Replacement, Battery: step 4, image 2 of 2
    • Peel off the black pieces of tape from the internal components.
  5. Vivitar XO 7 Motherboard Replacement: step 5, image 1 of 2 Vivitar XO 7 Motherboard Replacement: step 5, image 2 of 2
    • Carefully remove the battery from the tablet.
  6. Vivitar XO 7 Motherboard Replacement: step 6, image 1 of 2 Vivitar XO 7 Motherboard Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • With the tweezers, firmly grab the wire at the base and pull to disconnect the battery from the motherboard.
  7. Vivitar XO 7 Motherboard Replacement, Speaker: step 7, image 1 of 1
    • Carefully remove the speaker from the metal plate with your hands.
  8. Vivitar XO 7 Motherboard Replacement: step 8, image 1 of 2 Vivitar XO 7 Motherboard Replacement: step 8, image 2 of 2
    Buy
    • With tweezers, firmly grab the wire at the base and pull to disconnect the speaker from the motherboard.
  9. Vivitar XO 7 Motherboard Replacement, Camera: step 9, image 1 of 1
    • Peel off black tape that is holding the camera in place.
  10. Vivitar XO 7 Motherboard Replacement: step 10, image 1 of 1
    • Carefully disconnect the ribbon cables from the motherboard.
  11. Vivitar XO 7 Motherboard Replacement: step 11, image 1 of 2 Vivitar XO 7 Motherboard Replacement: step 11, image 2 of 2
    Buy
    • Using the tweezers, firmly grab wires and pull to disconnect them from the motherboard.
  12. Vivitar XO 7 Motherboard Replacement, Motherboard: step 12, image 1 of 1
    • Disconnect the large golden ribbon cable that is connected to the digitizer. Firmly grab the cable close to the connection and pull to disconnect.
  13. Vivitar XO 7 Motherboard Replacement: step 13, image 1 of 1
    • Remove four 4mm PH00 silver screws from the motherboard.
  14. Vivitar XO 7 Motherboard Replacement: step 14, image 1 of 1
    • Remove two 2mm PH00 black screws from the motherboard.
  15. Vivitar XO 7 Motherboard Replacement: step 15, image 1 of 1
    • Carefully remove the silver cover from the motherboard.
  16. Vivitar XO 7 Motherboard Replacement: step 16, image 1 of 2 Vivitar XO 7 Motherboard Replacement: step 16, image 2 of 2
    • Gently pick up and turn over the motherboard. While turned over, disconnect the last ribbon cable that connects to screen.
James Lunn
116 Reputation
1 Guide authored
USF Tampa, Team 11-1, Blackwell Winter 2015 Member of USF Tampa, Team 11-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G1
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 944
