Vizio CT15 Display Replacement
  1. Vizio CT15 Display Replacement, Vizio CT15 Back Panel Removal: step 1, image 1 of 2 Vizio CT15 Display Replacement, Vizio CT15 Back Panel Removal: step 1, image 2 of 2
    • Turn the laptop off and remove all power cables.
    • Remove the six Phillips #0 screws.
    • Pull the back cover off.
  2. Vizio CT15 Display Replacement, Battery: step 2, image 1 of 1
  3. Vizio CT15 Display Replacement: step 3, image 1 of 2 Vizio CT15 Display Replacement: step 3, image 2 of 2
    • Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
  4. Vizio CT15 Display Replacement, Display: step 4, image 1 of 3 Vizio CT15 Display Replacement, Display: step 4, image 2 of 3 Vizio CT15 Display Replacement, Display: step 4, image 3 of 3
    • Using your fingers, unplug the wires.
  5. Vizio CT15 Display Replacement: step 5, image 1 of 2 Vizio CT15 Display Replacement: step 5, image 2 of 2
    • Disconnect the display from the laptop base by pulling the two apart from each other.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 515
