Vizio CT15 Keyboard Replacement
  1. Vizio CT15 Keyboard Replacement, Vizio CT15 Back Panel Removal: step 1, image 1 of 2 Vizio CT15 Keyboard Replacement, Vizio CT15 Back Panel Removal: step 1, image 2 of 2
    • Turn the laptop off and remove all power cables.
    • Remove the six Phillips #0 screws.
    • Pull the back cover off.
  2. Vizio CT15 Keyboard Replacement, Battery: step 2, image 1 of 1
  3. Vizio CT15 Keyboard Replacement: step 3, image 1 of 2 Vizio CT15 Keyboard Replacement: step 3, image 2 of 2
    • Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
  4. Vizio CT15 Keyboard Replacement, Speakers: step 4, image 1 of 2 Vizio CT15 Keyboard Replacement, Speakers: step 4, image 2 of 2
    • Unplug the wire connecting the speakers to the motherboard.
  5. Vizio CT15 Keyboard Replacement: step 5, image 1 of 2 Vizio CT15 Keyboard Replacement: step 5, image 2 of 2
    • Remove the four Phillips #0 screws.
    • Pull the speakers out to remove.
  6. Vizio CT15 Keyboard Replacement: step 6, image 1 of 3 Vizio CT15 Keyboard Replacement: step 6, image 2 of 3 Vizio CT15 Keyboard Replacement: step 6, image 3 of 3
    • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull the ribbon cables out of the ZIF connector.
    • These wires are not connected to the speakers. We are only unplugging them to remove the wire underneath.
  7. Vizio CT15 Keyboard Replacement: step 7, image 1 of 2 Vizio CT15 Keyboard Replacement: step 7, image 2 of 2
    • Pull off the black strips of tape from the speaker wires and remove the speakers from the laptop.
  8. Vizio CT15 Keyboard Replacement, CPU Fan: step 8, image 1 of 2 Vizio CT15 Keyboard Replacement, CPU Fan: step 8, image 2 of 2
    • Unplug the fan from the motherboard.
  9. Vizio CT15 Keyboard Replacement: step 9, image 1 of 2 Vizio CT15 Keyboard Replacement: step 9, image 2 of 2
    • Remove the three Phillips #0 screws.
    • Pull the fan out to remove.
  10. Vizio CT15 Keyboard Replacement, Keyboard: step 10, image 1 of 2 Vizio CT15 Keyboard Replacement, Keyboard: step 10, image 2 of 2
    • Remove the four Philips #0 screws from the heatsink.
    • Pull up and out to remove the heatsink from the laptop.
  11. Vizio CT15 Keyboard Replacement: step 11, image 1 of 2 Vizio CT15 Keyboard Replacement: step 11, image 2 of 2
    • Remove the eight Phillips #0 screws from the motherboard.
    • Lift the motherboard up and out to remove it from the laptop.
  12. Vizio CT15 Keyboard Replacement: step 12, image 1 of 1
    • Remove the four Phillips #00 screws that hold the keyboard to the laptop case.
  13. Vizio CT15 Keyboard Replacement: step 13, image 1 of 3 Vizio CT15 Keyboard Replacement: step 13, image 2 of 3 Vizio CT15 Keyboard Replacement: step 13, image 3 of 3
    • Use a metal spudger to carefully push the keyboard out of place.
    • Carefully flip the laptop over and pull the keyboard out.
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 971
