Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement
  1. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement, Back Cover: step 1, image 1 of 1
    • Obtain the black plastic spudger tool from the iFixit toolkit. Position the device as shown in the picture. Insert the flat end of the spudger directly in the space above the power button between the back cover and front screen.
  2. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: step 2, image 1 of 1
    • Gently pry up on the plate with the spudger. You may hear some cracking noises as you work the spudger around your device, this is normal.
  3. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: step 3, image 1 of 1
    • Pry around the edges of the tablet with your fingers until you have successfully removed the back of the device.
  4. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement, Micro USB Charging Port: step 4, image 1 of 2 Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement, Micro USB Charging Port: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • The black ribbon can be easily damaged during this step, so proceed with caution.
    • Place the flat end of the black plastic spudger under the black plug and pry up to release the black ribbon. Using the metal tweezers, pull the black ribbon out of the plug.
  5. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: step 5, image 1 of 1
    • Remove all three 3mm-long silver screws using the T5 Torx screwdriver.
  6. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: step 6, image 1 of 3 Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: step 6, image 2 of 3 Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: step 6, image 3 of 3
    • Place the shovel end of the metal spudger under the speaker and pry upwards to remove the speaker from the device.
    • The speaker is secured to the device with adhesive glue so you may hear cracking noises while prying with the spudger.
  7. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: step 7, image 1 of 2 Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: step 7, image 2 of 2
    • Using the tweezers, grab a hold of the Micro USB assembly and gently remove it from the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 253
