VooDooQuad 250 Propeller Replacement
  1. VooDooQuad  250 Propeller Replacement, Propeller: step 1, image 1 of 2 VooDooQuad  250 Propeller Replacement, Propeller: step 1, image 2 of 2
    • Unplug the power cable of the drone to eliminate unnecessary mishaps.
  2. VooDooQuad  250 Propeller Replacement: step 2, image 1 of 1
    • With your set of pliers loosen and remove the four bolts holding the propellers to the motor.
  3. VooDooQuad  250 Propeller Replacement: step 3, image 1 of 2 VooDooQuad  250 Propeller Replacement: step 3, image 2 of 2
    • Gently remove the propellers perpendicular to the device.
    • When placing the new set of propellers on the drone, make sure that the wings angled upward are facing towards the center, or the battery.
Be careful removing the bolts multiple times because it may create slippage and then this will not allow the bolt nor the propeller to stay on. To reassemble your device, follow these instructions in reverse order
Damir Pamic
141 Reputation
1 Guide authored
USF Tampa, Team 10-3, Remmell Spring 2017 Member of USF Tampa, Team 10-3, Remmell Spring 2017
USFT-REMMELL-S17S10G3
4 Members
1 Guide authored
1 Guide Comment
Where do I purchase new perpelers
Will Smith - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 705
