Vornado 133 Compact Air Circulator Fan Blade Replacement
  1. Vornado 133 Compact Air Circulator Fan Blade Replacement, Grill Cover: step 1, image 1 of 3 Vornado 133 Compact Air Circulator Fan Blade Replacement, Grill Cover: step 1, image 2 of 3 Vornado 133 Compact Air Circulator Fan Blade Replacement, Grill Cover: step 1, image 3 of 3
    • Use a #1 Phillips screwdriver to remove the four 3mm screws.
    • It may be difficult to reach the bottom two screws; tilt the fan housing straight upwards for easier access.
  2. Vornado 133 Compact Air Circulator Fan Blade Replacement: step 2, image 1 of 2 Vornado 133 Compact Air Circulator Fan Blade Replacement: step 2, image 2 of 2
    • Once the screws are removed, turn the fan back over. Use your hands to pull the front grill cover off.
  3. Vornado 133 Compact Air Circulator Fan Blade Replacement, Fan Blades: step 3, image 1 of 3 Vornado 133 Compact Air Circulator Fan Blade Replacement, Fan Blades: step 3, image 2 of 3 Vornado 133 Compact Air Circulator Fan Blade Replacement, Fan Blades: step 3, image 3 of 3
    • Turn the center nut on the blade shaft clockwise to remove the nut, then remove the blades.
    • The nut is removed by turning clockwise, rather than the normal counterclockwise.
Erin Klein
483 Reputation
3 Guides authored
UW Tacoma, Team S1-G2, Liner Summer 2017 Member of UW Tacoma, Team S1-G2, Liner Summer 2017
UWT-LINER-SU17S1G2
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 36
All Time: 2,985
