Vornado 133 Compact Air Circulator Fuse Replacement
  1. Vornado 133 Compact Air Circulator Fuse Replacement, Fuse: step 1, image 1 of 1
    • Ensure the unit is powered off and remove the plug from the outlet.
  2. Vornado 133 Compact Air Circulator Fuse Replacement: step 2, image 1 of 3 Vornado 133 Compact Air Circulator Fuse Replacement: step 2, image 2 of 3 Vornado 133 Compact Air Circulator Fuse Replacement: step 2, image 3 of 3
    • Slide open the fuse access cover on the top of the plug by moving it towards the end of the plug.
  3. Vornado 133 Compact Air Circulator Fuse Replacement: step 3, image 1 of 3 Vornado 133 Compact Air Circulator Fuse Replacement: step 3, image 2 of 3 Vornado 133 Compact Air Circulator Fuse Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Use a pair of tweezers or a small plastic spudger to remove the fuse from the fuse casing. Remove the end nearer to the fan body first, then the end nearer to the plug end.
    • The replacement fuse must be 2.5 amp, 125 volt.
    • Do not push against the glass center of the fuse, only the metal end pieces.
Follow these instructions in reverse order to install the new fuse and close the access panel.
11 other people completed this guide.
Erin Klein
483 Reputation
3 Guides authored
UW Tacoma, Team S1-G2, Liner Summer 2017 Member of UW Tacoma, Team S1-G2, Liner Summer 2017
UWT-LINER-SU17S1G2
4 Members
4 Guides authored
10 Comments
Great post! This saved me $60 from buying a new fan! Thank you!
jamiekim808 - Reply
Thanks for posting. Ordered a pack of 50 fuses from amazon for $7.97
TLCIMMORTAL - Reply
Fast-acting or slow-acting?
James Olsen - Reply
Wow, I was going to throw this fan in trash and seeing your instructions I saved it
Anupam B - Reply
thanks buddy, just bought the fan ,son stuck a pencil in it , Quick fix
BOBBY C - Reply
Past 24 Hours: 7
Past 7 Days: 90
Past 30 Days: 311
All Time: 32,757
