Vornado Duo Circuit Board Replacement
  1. Vornado Duo Circuit Board Replacement, Circuit Board: step 1, image 1 of 2 Vornado Duo Circuit Board Replacement, Circuit Board: step 1, image 2 of 2
    • Start off by using a Philips #2 screwdriver to remove all 8 10mm exterior screws on the rear of the device.
  2. Vornado Duo Circuit Board Replacement: step 2, image 1 of 3 Vornado Duo Circuit Board Replacement: step 2, image 2 of 3 Vornado Duo Circuit Board Replacement: step 2, image 3 of 3
    • Carefully take front panel off.
  3. Vornado Duo Circuit Board Replacement: step 3, image 1 of 2 Vornado Duo Circuit Board Replacement: step 3, image 2 of 2
    • Loosen 5 mm screw at bottom of fan blade located inside the blades.
  4. Vornado Duo Circuit Board Replacement: step 4, image 1 of 2 Vornado Duo Circuit Board Replacement: step 4, image 2 of 2
    • Remove fan blade after unscrewing top 2 screws located on each side of the covered board.
  5. Vornado Duo Circuit Board Replacement: step 5, image 1 of 3 Vornado Duo Circuit Board Replacement: step 5, image 2 of 3 Vornado Duo Circuit Board Replacement: step 5, image 3 of 3
    • Remove cover from board.
  6. Vornado Duo Circuit Board Replacement: step 6, image 1 of 2 Vornado Duo Circuit Board Replacement: step 6, image 2 of 2
    • Unsolder the circled spots on the mother board and resolder each wire to corresponding spot.
2 other people completed this guide.
Tyler Pettenger
563 Reputation
3 Guides authored
USF Tampa, Team S1-G1, Nance Fall 2017 Member of USF Tampa, Team S1-G1, Nance Fall 2017
USFT-NANCE-F17S1G1
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 22
All Time: 895
