Vtech InnoTab 3S Camera Replacement
  1. Vtech InnoTab 3S Camera Replacement, Rear Panel: step 1, image 1 of 3 Vtech InnoTab 3S Camera Replacement, Rear Panel: step 1, image 2 of 3 Vtech InnoTab 3S Camera Replacement, Rear Panel: step 1, image 3 of 3
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Camera Replacement: step 2, image 1 of 2 Vtech InnoTab 3S Camera Replacement: step 2, image 2 of 2
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Camera Replacement: step 3, image 1 of 3 Vtech InnoTab 3S Camera Replacement: step 3, image 2 of 3 Vtech InnoTab 3S Camera Replacement: step 3, image 3 of 3
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Camera Replacement: step 4, image 1 of 1
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
  5. Vtech InnoTab 3S Camera Replacement, Camera: step 5, image 1 of 2 Vtech InnoTab 3S Camera Replacement, Camera: step 5, image 2 of 2
    • Using the tip of your finger, carefully pull the clip upwards to release the camera connection from the motherboard.
    • The connection between the motherboard and the camera is located at the near the top of the device.
    • Remove the camera and the connecting wire from the the clip and attach the replacement cameras connection to the latch on the motherboard.
    • Carefully lower the latch until you hear a click to secure the new camera to the device.
    • Pulling or tugging on the connection between the camera and the circuit board may cause damage to the connection.
2 other people completed this guide.
Karina Garcia
878 Reputation
6 Guides authored
USF Tampa, Team 8-2, Eyestone Fall 2015 Member of USF Tampa, Team 8-2, Eyestone Fall 2015
USFT-EYESTONE-F15S8G2
4 Members
9 Guides authored
4 Guide Comments
Where do you get the replacement camera? I can't find them online.
rongennero - Reply
I just did this whole thing...hoping it was a reset to the camera or something, but no, you need a replacement camera. Might be helpful to add that to the PARTS NEEDED part at the top, instead of saying "no parts required." UUGHHHH!
jpimash - Reply
Where can i buy the camera?
Stephan Meyer - Reply
kind of useless to post a replacement guide without suggesting a source for that replacement!!
Glen Fletcher - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 2,128
