Vtech InnoTab 3S Screen Replacement
  1. Vtech InnoTab 3S Screen Replacement, Rear Panel: step 1, image 1 of 3 Vtech InnoTab 3S Screen Replacement, Rear Panel: step 1, image 2 of 3 Vtech InnoTab 3S Screen Replacement, Rear Panel: step 1, image 3 of 3
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Screen Replacement: step 2, image 1 of 2 Vtech InnoTab 3S Screen Replacement: step 2, image 2 of 2
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Screen Replacement: step 3, image 1 of 3 Vtech InnoTab 3S Screen Replacement: step 3, image 2 of 3 Vtech InnoTab 3S Screen Replacement: step 3, image 3 of 3
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Screen Replacement: step 4, image 1 of 1
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
  5. Vtech InnoTab 3S Screen Replacement, Motherboard: step 5, image 1 of 2 Vtech InnoTab 3S Screen Replacement, Motherboard: step 5, image 2 of 2
    • Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
    • Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
    • Remove the six 3 mm screws securing the battery clip.
  6. Vtech InnoTab 3S Screen Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Using the tweezers, remove one battery clip from each corner (four total) of the Vtech InnoTab 3s.
    • With the tweezers, unsecure the charging port, headphone port, and the light switch button from the front panel of the device.
    • Potential for device damage: Avoid forceful movements when removing the motherboard to prevent damage of device components.
  7. Vtech InnoTab 3S Screen Replacement, Screen: step 7, image 1 of 3 Vtech InnoTab 3S Screen Replacement, Screen: step 7, image 2 of 3 Vtech InnoTab 3S Screen Replacement, Screen: step 7, image 3 of 3
    • Open the clip holding the screen plug with the yellow film.
    • The clip securing the screen is located at the top of the motherboard.
    • Remove all seven of the 5mm screws on the motherboard to separate the motherboard from the screen.
  8. Vtech InnoTab 3S Screen Replacement: step 8, image 1 of 2 Vtech InnoTab 3S Screen Replacement: step 8, image 2 of 2
    • Avoid forceful movements when separating the screen from the motherboard.
    • Carefully separate the motherboard from the device screen. Replace the damaged screen with an operational one.
Karina Garcia
878 Reputation
6 Guides authored
USF Tampa, Team 8-2, Eyestone Fall 2015 Member of USF Tampa, Team 8-2, Eyestone Fall 2015
USFT-EYESTONE-F15S8G2
4 Members
9 Guides authored
4 Guide Comments
What is the part number for the screen. Where can I buy one. Thank you.
david goodwin - Reply
what is the size of the screen
Adrienne Dooms - Reply
My grandson dropped his innotab 3 and now the screen is all scrambled. Can this be fixed? It did not crack the screen.
charma1963 - Reply
Where can I buy the replacement screen for the Vtech innotab 3S
Michael Kurrus - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 19
All Time: 2,424
