Vtech Innotab 3 Headphone Port Replacement
  1. Vtech Innotab 3 Headphone Port Replacement, Rear Panel: step 1, image 1 of 3 Vtech Innotab 3 Headphone Port Replacement, Rear Panel: step 1, image 2 of 3 Vtech Innotab 3 Headphone Port Replacement, Rear Panel: step 1, image 3 of 3
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
  2. Vtech Innotab 3 Headphone Port Replacement: step 2, image 1 of 1
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
  3. Vtech Innotab 3 Headphone Port Replacement: step 3, image 1 of 3 Vtech Innotab 3 Headphone Port Replacement: step 3, image 2 of 3 Vtech Innotab 3 Headphone Port Replacement: step 3, image 3 of 3
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
  4. Vtech Innotab 3 Headphone Port Replacement: step 4, image 1 of 1
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
  5. Vtech Innotab 3 Headphone Port Replacement, Headphone Port: step 5, image 1 of 3 Vtech Innotab 3 Headphone Port Replacement, Headphone Port: step 5, image 2 of 3 Vtech Innotab 3 Headphone Port Replacement, Headphone Port: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • On the front panel of the device, the headphone poet is located at the bottom right corner of the device, opposte of the speaker.
    • Using tweezers, lift up to remove the headphone port from its holding.
    • Be careful not to tug too hard when removing the headphone port for you may disconnect the wires from the solder
  6. Vtech Innotab 3 Headphone Port Replacement: step 6, image 1 of 3 Vtech Innotab 3 Headphone Port Replacement: step 6, image 2 of 3 Vtech Innotab 3 Headphone Port Replacement: step 6, image 3 of 3
    • Use tweezers to hold the four connecting wires away from the headphone port.
    • Desolder the four wires connected to the headphone port.
    • This is a tricky step. Refer to this guide to learn how to solder: How To Solder and Desolder Connections
Zach Diviney
419 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 292
