Vtech Innotab 3 Microphone Replacement
  1. Vtech Innotab 3 Microphone Replacement, Rear Panel: step 1, image 1 of 3 Vtech Innotab 3 Microphone Replacement, Rear Panel: step 1, image 2 of 3 Vtech Innotab 3 Microphone Replacement, Rear Panel: step 1, image 3 of 3
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
  2. Vtech Innotab 3 Microphone Replacement: step 2, image 1 of 1
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
  3. Vtech Innotab 3 Microphone Replacement: step 3, image 1 of 3 Vtech Innotab 3 Microphone Replacement: step 3, image 2 of 3 Vtech Innotab 3 Microphone Replacement: step 3, image 3 of 3
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
  4. Vtech Innotab 3 Microphone Replacement: step 4, image 1 of 1
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
  5. Vtech Innotab 3 Microphone Replacement, Microphone: step 5, image 1 of 3 Vtech Innotab 3 Microphone Replacement, Microphone: step 5, image 2 of 3 Vtech Innotab 3 Microphone Replacement, Microphone: step 5, image 3 of 3
    • Remove the four 7.6 mm screws using a PH00 screwdriver.
    • Lift up the circuit board from the device.
  6. Vtech Innotab 3 Microphone Replacement: step 6, image 1 of 3 Vtech Innotab 3 Microphone Replacement: step 6, image 2 of 3 Vtech Innotab 3 Microphone Replacement: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • To replace the microphone, desolder the two connections that connect the speaker to the device.
    • Use tweezers to keep the microphone steady as you desolder the connections.
    • This is a tricky step. Refer to this guide to learn how to solder: How To Solder and Desolder Connections
Zach Diviney
419 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 11
All Time: 484
