Vtech Kidibeats Drum Set Battery Replacement
  1. Vtech Kidibeats Drum Set Battery Replacement, Battery: step 1, image 1 of 1
    • Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
  2. Vtech Kidibeats Drum Set Battery Replacement: step 2, image 1 of 1
    • To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
    • You can also use a small coin to loosen the screw.
  3. Vtech Kidibeats Drum Set Battery Replacement: step 3, image 1 of 1
    • Using your fingers, pry open and remove the back battery panel.
  4. Vtech Kidibeats Drum Set Battery Replacement: step 4, image 1 of 1
    • Use your fingers to remove each battery from its housing.
    • When inserting the new batteries, remember to match them according to the image displayed on the battery panel.
Aaron Klementowski
820 Reputation
6 Guides authored
USF Tampa, Team 2-8, Cagle Spring 2016 Member of USF Tampa, Team 2-8, Cagle Spring 2016
USFT-CAGLE-S16S2G8
2 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 938
