Vtech Kidibeats Drum Set White Drum Head Replacement
  1. Vtech Kidibeats Drum Set White Drum Head Replacement, Back Panel: step 1, image 1 of 1
    • Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
  2. Vtech Kidibeats Drum Set White Drum Head Replacement: step 2, image 1 of 1
    • To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
    • You can also use a small coin to loosen the screw.
  3. Vtech Kidibeats Drum Set White Drum Head Replacement: step 3, image 1 of 1
    • Using your fingers, pry open and remove the back battery panel.
  4. Vtech Kidibeats Drum Set White Drum Head Replacement: step 4, image 1 of 1
    • Use your fingers to remove each battery from its housing.
  5. Vtech Kidibeats Drum Set White Drum Head Replacement: step 5, image 1 of 1
    • Using a Phillips #2 screwdriver, loosen and remove the six 14 mm screws.
  6. Vtech Kidibeats Drum Set White Drum Head Replacement: step 6, image 1 of 2 Vtech Kidibeats Drum Set White Drum Head Replacement: step 6, image 2 of 2
    • With your hands, separate the bottom panel from the drum set.
    • When removing the bottom panel, be careful not to pull too hard in order to prevent damaging the connections from the motherboard to the speaker and power source.
  7. Vtech Kidibeats Drum Set White Drum Head Replacement, White Drum Head: step 7, image 1 of 2 Vtech Kidibeats Drum Set White Drum Head Replacement, White Drum Head: step 7, image 2 of 2
    • To replace the white drum head on the cymbal side, use a Phillips #00 screwdriver to loosen and remove the two 8 mm screws.
    • To replace the white drum head on the side opposite of the cymbal, use a Phillips #00 screwdriver to loosen and remove the two 8 mm screws.
    • The blue drums will fall after the screws are loosened. Be sure to brace the blue drums in this step in order to prevent damage to the connection points between the blue drum components and the motherboard.
  8. Vtech Kidibeats Drum Set White Drum Head Replacement: step 8, image 1 of 1
    • Loosen and remove the five 15 mm screws using a Phillips #2 screwdriver.
  9. Vtech Kidibeats Drum Set White Drum Head Replacement: step 9, image 1 of 1
    • Using your hands, remove the orange rim and white drum head from the blue base.
  10. Vtech Kidibeats Drum Set White Drum Head Replacement: step 10, image 1 of 1
    • Using your hands, pull apart the white drum head from the orange rim.
Aaron Klementowski
820 Reputation
6 Guides authored
USF Tampa, Team 2-8, Cagle Spring 2016 Member of USF Tampa, Team 2-8, Cagle Spring 2016
USFT-CAGLE-S16S2G8
2 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 476
