Vtech Kidizoom Smart Watch DX Battery Replacement
  1. Vtech Kidizoom Smart Watch DX Battery Replacement, Master Switch: step 1, image 1 of 1
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
  2. Vtech Kidizoom Smart Watch DX Battery Replacement: step 2, image 1 of 1
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
  3. Vtech Kidizoom Smart Watch DX Battery Replacement: step 3, image 1 of 1
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Battery Replacement: step 4, image 1 of 2 Vtech Kidizoom Smart Watch DX Battery Replacement: step 4, image 2 of 2
    • Lift the master switch from the circuit board.
  5. Vtech Kidizoom Smart Watch DX Battery Replacement, Circuit Board: step 5, image 1 of 2 Vtech Kidizoom Smart Watch DX Battery Replacement, Circuit Board: step 5, image 2 of 2
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
  6. Vtech Kidizoom Smart Watch DX Battery Replacement: step 6, image 1 of 1
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Battery Replacement: step 7, image 1 of 1
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Battery Replacement: step 8, image 1 of 1
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Battery Replacement: step 9, image 1 of 1
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
  10. Vtech Kidizoom Smart Watch DX Battery Replacement, Battery: step 10, image 1 of 2 Vtech Kidizoom Smart Watch DX Battery Replacement, Battery: step 10, image 2 of 2
    • Using the plastic opening tool, gently pry the edges of the battery away from from the circuit board.
    • There is a thin layer of adhesive holding the battery to the circuit board. This will remain sticky after prying.
  11. Vtech Kidizoom Smart Watch DX Battery Replacement: step 11, image 1 of 1
    • De-solder the red battery wire from the circuit board.
  12. Vtech Kidizoom Smart Watch DX Battery Replacement: step 12, image 1 of 1
    • Repeat the de-soldering for the black (ground) wire.
  13. Vtech Kidizoom Smart Watch DX Battery Replacement: step 13, image 1 of 1
    • Pull the battery free, and wait for the solder to cool before handling further.
4 other people completed this guide.
Navin Ramkishun
259 Reputation
1 Guide authored
USF Tampa, Team 10-6, Remmell Spring 2016 Member of USF Tampa, Team 10-6, Remmell Spring 2016
USFT-REMMELL-S16S10G6
4 Members
12 Guides authored
One Comment
Where did you bought the battery?
funkysoulbrother - Reply
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 47
All Time: 9,386
