VuPoint DC-ST210-VP Battery Door Cover Replacement
  1. VuPoint DC-ST210-VP Battery Door Cover Replacement, Turn Off/Remove Batteries: step 1, image 1 of 1
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: step 2, image 1 of 3 VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: step 2, image 2 of 3 VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: step 2, image 3 of 3
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. VuPoint DC-ST210-VP Battery Door Cover Replacement, Pry Backplate Off: step 3, image 1 of 2 VuPoint DC-ST210-VP Battery Door Cover Replacement, Pry Backplate Off: step 3, image 2 of 2
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Battery Case Screw: step 4, image 1 of 1
    • Remove the 4.5mm screw with the iFixit ph#00 screwdriver
  5. VuPoint DC-ST210-VP Battery Door Cover Replacement, Open the Battery Case: step 5, image 1 of 2 VuPoint DC-ST210-VP Battery Door Cover Replacement, Open the Battery Case: step 5, image 2 of 2
    • With your fingers, gently pull the two pieces of the battery case apart. At this point, the battery door should be exposed
  6. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove the Battery Cover: step 6, image 1 of 1
    • With your fingers, gently remove the battery door.
    • Now you are free to repair or replace the battery door! Follow these steps in reverse order to reassemble the camera.
2 other people completed this guide.
Elise Brown
70 Reputation
2 Guides authored
Baylor, Team 8-15, Williams Fall 2014 Member of Baylor, Team 8-15, Williams Fall 2014
BU-WILLIAMS-F14S8G15
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 391
