WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Chamber Gasket Replacement
  1. WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Chamber Gasket Replacement, Pressure Regulator Chamber Gasket: step 1, image 1 of 1
    • Using a 4mm Allen wrench, remove the 4 Allen screws, 44mm in length, from the yellow cap on the back of the brad nailer.
  2. WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Chamber Gasket Replacement: step 2, image 1 of 1
    • Remove the yellow cap to reveal the gasket.
    • Keep the nailer upright so the piston does not fall out. If the piston falls out, simply put it back in place.
  3. WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Chamber Gasket Replacement: step 3, image 1 of 1
    • Remove the faulty gasket and replace it with a new gasket.
Ousman Jammeh
507 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 271
