WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Knob Replacement
  1. WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Knob Replacement, Pressure Regulator Knob: step 1, image 1 of 1
    • Using a 2mm Allen wrench, remove the Allen screw located on the pressure regulator knob on the back of the brad nailer.
  2. WEN 18 Gauge 2-Inch Air Brad Nailer Pressure Regulator Knob Replacement: step 2, image 1 of 1
    • Remove the knob from the gun and replace the knob.
    • Be aware of the rubber spacer that will come off with the knob; when you replace the knob put the spacer back in the middle around the screw hole.
Ousman Jammeh
507 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 249
